i've burnt movies with + and - Rs, and i went to burn a full movie i download and it skips like crazy towards the end, so i decided instead of wasting all those DVDRs i bought some Sony DVD+RWs so i can write and if the dvd is in great quality then i'll burn to a DVDR, but i was wondering would a PS2 play DVD+RWs? And another thing is; since i downloaded the full DVD that skips what do you think the problem would be? the one i downloaded has all the VTS files, and since it skips i'm redownloading the movie but it has the .img file, so i'm thinking that i just burn it? i've never worked with that file before.
DVDdecrypter or Nero should be able to burn an image file.
You should be able to mount the image with Daemon Tools and view the file before you burn it with something like PowerDVD.
For image programs, look to the left under 'Tools'.
Skipping towards the end is usually indicative of problem media. Try reducing the size of the DVD with Shrink and see if that helps.
Don't know about PS2, sorry. -
how would you shrink VTS files? and plus DVD+RWs don't play on PS2 well at least not mine...Originally Posted by redwudz
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 06:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 21:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 21:47
