I've read where people cleans the lense on the recorder/player,Are they using the can of compress air as the first try,or are there more appropiate ways? A newbie wanting to learn?
they sell a brush/liquid disc
http://www.directron.com/cdlens.html
if you can't get a qtip with isopropyl 99% alcohol into the mechanism -
Just a word of caution; most, if not all, of the lasers used in CD/DVD devices have anti-reflective surface coatings which can be damaged by cleaning, so don't over do it, and be careful.
Proud Member of the Unofficial LiteOn/iLO Beta Testers Club. -
Ok, Thanks Guys,But i thought i read where you can blow compressed air(as you use on the computer) in there ,maybe just to clean dust etc. Is this, ok & safe?????
Yeah, you can use compressed air thats for electronics...Turn the machine off first cause the air can sometimes drip a liquid. Its getting it to aim right thats the trick.
I don't know if it works, but Philips has a dvdrecorder cleaner, it has very fine brushes as compared to a cd cleaner. Again, I don't know if it works as I won't use it till there are problems.
I use methylated spirits (denatured alcohol) for cd/dvd lasers and it does a good job.
Dip a cotton bud in meths and just stroke across the laser once, wait about 5 mins and pop in disc. -
Try the canned air first. Then maybe a cleaning disk, as long as it's not abrasive.
For real cleaning, you may have to take the unit apart, clean with denatured or 99% isopropyl alcohol with a foam Q-tip type cleaner. A cotton Q-tip will work, but make sure you leave no fibers. Keep the Q-tip fairly dry, so you don't drip any alcohol on the laser slide and wash off the lubricant.
It is always risky to clean a DVD laser. Most manufactures recommend against it. Look at it this way, if the drive doesn't work, you are no worse off. If it's under warranty, exchange it instead.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
"Dirty disk" problem after burning. PLS HELP!
By mlo2102 in forum Authoring (DVD)Replies: 9Last Post: 29th Jun 2011, 15:17 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
C 13 60 "The Disc is Dirty"
By Hikari112 in forum Authoring (DVD)Replies: 5Last Post: 23rd Aug 2007, 18:44 -
Editing self-owned dvd movies to make "clean versions" for my fam
By nef1l1m in forum EditingReplies: 5Last Post: 1st Aug 2007, 14:00
