  1. i keep having problems with the audio. i try to using VirtualDub and the audio is still off. i tryed installing codec after codec and the audio is still off. i even tryed AVI audio decompressor ver 1.4 ,witch i used all the time with windows ME, but ever since i changed to XP i cant get the audio to be on. what can i do to get the audio to be on? i would like someone to recommend codecs for XP, because i cant get it right. the audio is always off, what ever codec i install. the audio only goes off when i convert it.
    please help, this is realy getting frustrating
  2. You are saying you never had audio sync problems when you were using Wndows ME?
  3. Member daphy's Avatar
    Europe
    what type of sound is inside your avi -> ask gspot, it will tell you codec is missing (maybe itīs a AC3 )
