If i rip my mpegs to DVD using TMPGEnc can i burn the DVD mpgs to a disc to play on my DVD player?
You won't find any mpeg files on yuor DVD. You'll only find VOB's. You can in effect rip the VOB's and then encode them with an encoder of you choice to another viewable format. The format you want is dependent on what quality you want and what of course your standalone DVD Player will accept.
I suggest you read the basics first - the different formats i.e. VCD,SVCD etc. (under the "what is?" section of this website) and then once you have decided what you want carry on with the Guides on this website.
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 12:08 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 20:47
