Just got a quick question. I have a AVI file thats at 640x352. For my output file, should i set it at 352x480 or 352x240? Is 240 too low? Thanks![]()
352x480 is a NTSC standard, but you would need to set the output resolution to something that keeps the aspect ratio (or puts right the aspect ratio).
For example, 352x240 is not too low if the film is in letterbox.
Hope that this is helpful.Cole -
352x480 would be much better,if your avi is good quality then you will see the difference.
