1st, thanks for S2D - I love it. and thanks for VOB2MPG, it saved the day for me the other night
BUG: When running v2.0 RC 2, in "don't burn" mode the target HD filled up btwn VOB sets 7 and 8 [the last]
S2D ran to completion saying it was done, with ALL the typical encouraging end-msgs in the log but of course #8 was missing from the output files.
The bottom progress meter correctly showed that indeed S2D was not done.
Freeing up space did not cause it to finish up.
XP HOME with SP1.![]()
DVD Decrypter burn method?
That was probably set in Settings/Burning, that's where it is tonight. Did notOriginally Posted by ChrissyBoy
pay much attention since at the last step I had said "Dont Burn".
I would be happy to email you the LOG and a screen shot I took - what email addie should I use ?
BTW, now having looked at the log file I see that behind the scenes, S2D detected the problem, e.g.: "23:56:50: ***: Error writing data"
Cheers, P-PA
try badger (at) svcd2dvd.com
full bluray disc to mkv or avchd
By Melvin18 in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Apr 2010, 11:26 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 06:12 -
BD-9 Full Disc on PS3
By teedster in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 01:51 -
How do I report a bug in SUPER?
By rafwuk in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2009, 10:39 -
Syntax bug in SVCD2DVD
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Nov 2007, 12:14
