If you put a DVD-R or DVD+RW disc in a DVD-RW burner then you try to burn a home movie into it, it won't burn correctly? The DVD-RW burner can only burn DVD-RW discs?
A burner is a burner. Most will do -R, -RW, +R and +RW, and some will also do DVDRAM.
What make and model is yours?Cheers, Jim
My DVDLab Guides -
dogg, put your burner model, etc. in your user profile. That way we can see what you are using and you won't have to tell us whenever you have a question. Thanks
P.S. - If you had your burner listed in your profile, we could answer your question. OR, you could have looked up your burner in the 'DVD Writers' on the left, they will tell you what burners can burn what. -
https://www.videohelp.com/dvdwriters.php?DVDnameid=20&Search=Search&list=2#comments
DVD-R, but NOT DVD+R!Cheers, Jim
My DVDLab Guides
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 14:54 -
Converting .VRO file onto a DVD disc (to play on standard DVD players) ?
By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 17:40 -
Copying,Copied DVD-Rw disc to,DVD-R disc
By 306james in forum DVD RippingReplies: 3Last Post: 12th Nov 2007, 11:45 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 04:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50
