I would like to be able to edit video with multiple audio tracks selectable when i burn it to dvd. one audio track is with the original file and the second i would like to add music files instead using vegas and edit the video itself (and the same time the original audio to avoid sync issues) is this possible in vegas or dvd architect? if not can you tell me what i need to get it done.
thanks
it is a simple thing w/ vegas+DVDA ... you dont need anything else ...
you render the audio seperate anyway ... and you can have unlimited audio tracks in vegas .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks, is therer quick guide anywhere, have checked the guides section and kind find anything, any help would be much appreciated
Just Look in the help Files there Is lots of Info, you can Search Google for Vegas forums.
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Looping Video Multiple Audio tracks
By doctor in forum Authoring (DVD)Replies: 6Last Post: 19th Dec 2008, 10:37 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
VOB to .ts with multiple audio tracks
By csaba1985 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 07:28 -
DVDShrink - Multiple audio tracks? What's what?
By kelemvor in forum DVD RippingReplies: 17Last Post: 16th Jul 2007, 11:07
