Results 1 to 11 of 11
Thanks for the heads up. After looking through the change log, to me, it looks all so juicy; you know, good stuff.
if you read the reviews at versiontracker.com, you will find a direct link.
don't use a browser, but try Monica instead. you can download the update without a login at Roxio.
dk -
ROXIO Germany has confirmed problems that if you try to download the file using a non-US Browser or Mac OS X you are stuck in a loop with their links. They gave me a working link by phone.
Cheers,
Joachim -
I used OS X, with Monica.
http://www.macupdate.com/info.php/id/5838 -
i had no problems at all using safari with os x and i was getting the update right when it came out
As reported in German forums, it seemed to have worked right after being issued. Problems arose later for non-US customers.
Cheers,
JoachimS -
What are the new features, or a link to the new features?
A picture is worth a thousand words, but a good camera is worth about a thousand bucks. -
Joachim - problem is now fixed for non-US customers. People outside of US are able to download the updated from Roxio's web site.
Toast 7
By JordanBlake in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2010, 15:07 -
Alternatives to Toast
By danielmak in forum MacReplies: 6Last Post: 16th May 2010, 23:37 -
Toast 10.0.2 question
By danielmak in forum MacReplies: 1Last Post: 10th Jul 2009, 08:24 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 22:45 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 06:00
