I have seen video files with the ending *.bin, how can I view or convert such a video file into Mpg or better SVCD format?
A "*.bin" File is special file format that you get out from a burning Program (Like "Nero", for exaple) "*.bin" and "*.cue" files is what you obtain if you copy a CD in to a "image recorder"; that is a way to Copy a Cd. Look to the help of your burning programs, look for Image recorder.
To answer your question, With the Bin file alone you can't do nothing. You have to look for the Cue file also, and try to burn your CD again (look for Image recorder). Then you have to convert the DAT file you get onto the CD....but is a long work! -
To convert bin cue files you need VCDGEAR
ro you can burn it with CDRWIN or FIREBURNER
Avidemux crashes with many, many MP4 files. How to handle?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 20:55 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
how to handle mp4 and mts(canon) files.
By dainova in forum EditingReplies: 1Last Post: 9th Aug 2010, 06:25 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 22:57 -
VOR files - how do I handle these ?
By Bansaw in forum Video ConversionReplies: 4Last Post: 21st Jun 2007, 12:19
