Hi
I have two AVI files of a recorded show that I want to put on one dvd disc for easier watching on a standalone dvd player.
I tried to use VirtualDUB to append the two seperate AVI's together before reencoding them to MPEG for the DVD author but it wont append the second file because the bitrate of the audio is different.
Is there an easy way to fix this problem or match the two audio bitrates so i can append the avi's into one file and then onto MPEG2 for DVD burn?
Hope you all can help because after searching through the forums dont find an easy solution.
Have also seperated the audio of the two avi's out using virtualdub to wav files but not sure what to do after this so I dont introduce more problems like audiosync. Not even sure if this will take care of the issue.
thanks in advance
Ashley![]()
Try selecting No Audio before importing the other clip. Once they are merged, select Wave file for the audio and import your merged audio.
It should work, if you didn't edit the sound files and did a straight cut 'n paste to merge them. -
You could also use the batch facility of TMPENC (If you are using that) and make two separate MPG files. Then just import then into your autoring package (I use ulead, and this works just fine
Good luck
Ironballs -
I would also go this route of making two mpegs. Your dvd author should then let you add both mpegs to same disc. I wouldn't mess with trying to combine. I use TMPGENC Author and you can even added both mpegs to same track where say if it was one movie or show that had been split into avi's, when played back on stand alone, you couldn't even tell it was 2 diffrent files
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09 -
Combine two AVI with AC3 audio
By vassie in forum Video ConversionReplies: 3Last Post: 25th Dec 2010, 03:52 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 17:50 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 16:45 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 03:23
