Hi all,
I have checked all over the place and either people dont understand what I am saying or they dont know.
I have some software that is on 5 iso's I want to put them all together some I have only 1 iso to burn to dvd. I also want to be able to install the program with the 1 iso with a program like winiso. I also want to be able to fit the 1 iso on a dvd and be able to install the program that way.
How do I do this???
What do you mean you "want to be able to install the program with the 1 iso with a program like winiso"?
I haven't used winiso, is it able to mount an iso and run the software? If so, just burn all 5 separate iso files to a DVD and use your winiso. I wonder if daemon tools could mount an iso of a DVD?
Also, you could extract all the files from the iso with isobuster. Make a separate folder for each iso you extract, then burn all the files to a DVD.
If there's only one setup for all these iso and you have to swap disc to install; you might be able to copy all the extracted files to a single folder, then you wouldn't have to swap disc. This is only possible if no files get overwritten as you copy the files to the same folder. When you burn the files to a disc, just put everything in the root, unless there are sub-folders. -
To install with 1 iso , you open it up in winso hit install and the whole program intalls no disk swapping.
I put all 5 iso's on 1 dvd and when the time comes for the 2nd iso to install it asks for a disk it wont install from the dvd.
Why is that why cant it install from 1 dvd??? -
Probably because the install routine (or whatever you call it) isn't set up to copy from one physical disc. The install was probably built around the premise that would be several discs.Originally Posted by motay
burn the actual image file(s) on to dvdR, burn daemon tools installer to dvdR too. mount image file with daemon tools from dvdR.
how do you make an .iso file using dvdfab hd decrypter?
By Beautiful Alone in forum DVD RippingReplies: 41Last Post: 15th Aug 2011, 06:38 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Using DVDFab to make ISO file from BD?
By neworldman in forum Blu-ray RippingReplies: 1Last Post: 5th Apr 2010, 06:40 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
