rkr1958 wrote:
No, you're not missing anything. It's just a bunch of people expressing their opinions, but it's only "Their Opinions". I agree with your findings.My first set of scans is from Nero 5 buring the VIDEO_TS & AUDIO_TS folders (NOT from burning and image but burning files). The second set of scans is DVDDecryptor burning an iso file made by TMPGEnc DVDAuthor from the Video_TS file. I really can tell a difference in the quality of the two burns. It looks to me that using Nero to burn the video files (not the image) produces the same quality burn as using DVDDecryptor with an iso image. Am I missing something here?
We're talking about digital data here not analog. It's just a bunch of ones and zeros. The job of the Burning s/w is to send the ones and zeros (in the correct format) to the burner witch then burns those ones and zeros (in the correct format) to the disk. There is simply a much higher risk of failure with the burner and media than there is for the s/w, provided the s/w is not flawed.
Results 31 to 37 of 37
This is untrue.I switch from time to time between both s/w, only using ISO files, and I am quite satisfy. Sometimes I do not have a choice but using Nero because dvddecrypter cannot burn nero recode *.nrg files.
It most definately can handle .nrg's just fine.
Seth:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
would making a image burn instead of a regular "video" burn with nero or dvd decrpyter to improve player playback compatabily?
Would burning UDF files make a difference in this test?
Also, Nero has the "Force DVD-Video Compatibility Mode" option that I cannot find on any other program.Don't Hate The Player, Hate The Game. -
That was a great comparison. I guess maybe I should stop using Nero to burn all my DVD's ?
Cuban Cigars, Women and Movies.... What a wonderful combination!... I have a web site, and I've seen it... HAVE YOU!?
If you can read this, you do not need glasses -
If nero works for you, then great..
Wouldnt bother changing something that's not broken. Remember, these tests are just examples of burns done on my machine..and even though the burn process was kept as close as possible to circumstances, there are always unseen variables. Could be something as small as CPU temperature that would make something ever so slightly different, etc.
Scans really should be taken with a grain of salt, and as long as what you're doing is producing acceptable results for you, then I wouldnt even worry about it.
I do believe the quality of burns is slightly effected pending the program used, however, the PIF/PI differences shown in this set of scans, wouldnt even be close to enough under normal circumstances to produce anything different when it comes to the playback of the DVD on a stand alone.
Like I said...most of it is really preference.
Archived DVD Scans
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
IMG Burn says - File too large!
By orfajackson in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2009, 14:41 -
Question how to burn (img, ccd, sub) with Nero
By jimdagys in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2008, 09:35 -
I/O Error in IMG Burn - Help!
By msdker in forum Newbie / General discussionsReplies: 7Last Post: 22nd May 2008, 00:11 -
burn with dvd decrypter but copy by nero ?
By GINZY in forum DVD RippingReplies: 2Last Post: 6th May 2007, 08:05
