Hello Members.
I have try to burn harry potter1 MPG,723MB 72:30.31.min on are 90 Arita CD-80rplus with Nero/ but Philips Pcrw804 burner not responding to finisch the burning process.nero say's put are empty cd in your drive.i have putt are new CD 90MIN but the same problem
What can i do to burn the movie.
Please help me.
Greatings from Hans.
Results 1 to 13 of 13
FTPduren
you mean it burns but it doesnt Finish???????? if soo does nero some where says do you want to overburn ..if sooo just say yes and it will finish the burn process ....and if have a older NERo that might be the problem get the latest one...if you versoin is 5.0.X.X then you get a free upgrade sooo try the overburn or get the latest one on there weeb page
_________________
<font size=-1>[ This Message was edited by: pinoy2201 on 2001-12-08 05:47:48 ]</font> -
FTPduren, 723mb should fit nicely even on a 74min CDR, I don't see why you are trying to use 90min media.
Also, to support 90min media, your CDRW (your Philips) must be capable of overburning to 90min, most older CDRW drives will only do upto 80min.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hello.
Thansk for responding my question.But nero dont start the burningprocess
_________________
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
Hello Sefy.
Thanks from Responding.I have only Arita -700MB for Data and 730MB for Audio,and 90min cd-r Plus
I think my Philips don support it.
Thanks.
Greatings From Hans.
I use Nero - Burning Rom,5.5.4.0
quote]
_________________
[/quote] -
Hello Terratom.
Thanks for responding,i can try it.
On 2001-12-08 08:19:46, Terratom wrote:
Hi,
YouŽll have to allow Nero to overburn CDŽs:
Options->Expert
Bye,
Terratom
FTPduren -
Hello Terratom.
Help Me out with the settings for using Nero.
Yellow marker Min 74,sec.0,fm,0.
Red Marker Min 90,sec,0,fm,0
Or schoult i go to Exper features maximum CD-length 90 min.
Greatings From Hans. -
On 2001-12-08 08:42:46, FTPduren wrote:
Hello Terratom.
Hi Hans,
Go to Expert Features and set the length to 90 min.
If you do so Nero will still complain about not enough diskspace but will then offer you to burn the cd anyway.
Ah! - donŽt forget to select "disc at once" instead of "track-at-once" in the same menu where you determine
the writeing speed.
I hope that helped
Bye,
Terratom
Hello Terratom.
Thanks for responding,i leth you nowe when the have succesfuly burnit.
Thanks.
Hello Terratom.
I have burning the cd succesfuly on are 80 minut cd.
Thanks for helping me out.
If it's a genuine MPEG1 , you can burn as a VCD in Nero and it will fit on a 74" CD.
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video Streaming DownloadingReplies: 5Last Post: 6th Mar 2010, 15:59 -
Why does it only convert 15 min. worth?
By woodcliff in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2009, 21:11 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 09:59 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 01:46 -
Replaying a 10 min section
By elute96 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 15:03
