hey everyone
im trying to convert .vob (or .m2v if need be) to a format readable in Final Cut Pro 3 (academic)
heres the slight problem, we're running OS 10.1.5 here (at school) and would prefer not having to upgrade. does anyone have any suggestions on what i should do?
:: ehmjay.
Some sort of AVI codec.
I don't think you can directly read MPEG files in FCPWant my help? Ask here! (not via PM!)
Grab a copy of MPEG Streamclip and use the Convert to Quicktime option. If you need NO loss use the animation codec. I usually use the Motion JPEG A codec.
Get a copy of the mpeg-2 component (compatible with 10.1.3) and use Quicktime Pro (came with FCP) to translate the video to quicktime. Export the sound to AIFF and import both to FCP.
alright i finally found one, however all i need now is just audio conversion...
any ideas??
i do have the file
"dolby-rain.vob.mp2" which i cant play in iTunes or FCP so i have to convert it, any one know what i should do.
bear in mind-im on mac os 10.1:: ehmjay. -
okay so the thing i found will not work.
pixel...you say i have Quicktime pro, however my quicktime says its just standard? is this because the teacher who set this up didn't set quicktime to be pro? if so, how can i make it pro?
also, do i have to buy the mpeg-2 component or should it be on the comptuer allready.
sorry i cant be more specific, but because i dont actually OWN this computer i dont know exactly what is on it.:: ehmjay. -
QuickTime 6 MPEG-2 Playback Component -- $19.99 from online Apple Store.
Final Cut Pro: Converting FCP formatted .MOV to PC compatible format
By 6079 in forum Video ConversionReplies: 6Last Post: 23rd Sep 2010, 08:29 -
IVTC a vob/m2v file before FCP editing
By kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 02:15 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Converting VHS into FCP
By James in HD in forum MacReplies: 6Last Post: 3rd Jan 2008, 02:28
