Hi all,
I thought it might be a good idea to have people upload their DVD lab/DVD lab pro/Encore etc DVD menus so everyone can see them? What do we think?
If it sounds ok and ppl are up for it i'll post my first switched effort in DVD lab!
stokefan
Results 1 to 20 of 20
good enough for me @ home
my first effort in DVDlab pro, I was pretty happy with it except for some reason you can't see both menu items on the screen at the same time, they only appear when they're selected
that is because you erased somehow the top layer and only seeing the bottom layer for those sections ..
oh right thanks BJ_M.
My aim is to make a DVD menu for a home movie with real movies as the transitions between scene selections. I'll post pics of that when it's made. Altho i'm sure i'll be posting here for help when iv started it
Here's one I threw together for fun.
http://members.shaw.ca/videojunk/menu1.aviCheers, Jim
My DVDLab Guides -
Here's one of mine:
Of course the original is much better quality. -
thats nice .. like it ..Originally Posted by reboot"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Another. Fully Blown!
http://members.shaw.ca/videojunk/menu2.aviCheers, Jim
My DVDLab Guides -
I like the second one, and NOT just because it's got nekkedness
Most of my menus are simple text links as well. I just wanted to show some outrageous stuff DLP will do.Cheers, Jim
My DVDLab Guides -
Hey reboot,
What the hell codec did you use? I can't open either one. -
No, I don't do divix. I primarily work with DV material.
I figured DivX would be the most compatible...sorry, I could have said
Cheers, Jim
My DVDLab Guides -
Here's my 1st attempt with Switched Menus:
It's a Music DVD I made of all of Led Zeppelin's albums. The Led Zep fans out there will quickly see I used Led Zeppelin IV's album cover for the main background. I extracted the image of the old man and used the frame for the port-hole to view the album sellection. I give that a Cool Factor of ten. -
Hello everyone
Here's mine. Hope you all like. It was real quick and dirty, but its a good
start in the right direction.
.. If all doesn't go well w/ the pics, (having trouble
.. with the links) I'll fix later.
From the Video Workstation of,
-vhelp 3116
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 13:54 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
Cell Menus Dvd lab pro
By angelus214 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2008, 10:52 -
Post your dvd menus here
By zanos in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 01:16 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 19:10
