Hi
I LIKE to make my own memus inPhotoshop and import them to DVDLab.
i looking for a good toturial on how to bring already made menues and have them work on my DVD's VTS.
tHANKS
S
Results 1 to 11 of 11
Import your menu. Set it as background in the menu in dvdlab.
Click the hotspot button, draw a box around the spot you want to use for a link, then link it to something.Cheers, Jim
My DVDLab Guides -
how the text of the hotspoted image will highlight when interact with the DVD remote control? and what pixel aspect ratio i should use in Photoshop when i set the image to 720x540?
photoshop has pal and ntsc project settings and export ..
The text won't be hilighted, the hotspot box will.
If you want text hilighting, don't put any text on your Photoshop menu, use DVDLab's text tool instead.
The other option is to save a multi-layer image. Not sure if Photoshop can do that, and I've never played with it.Cheers, Jim
My DVDLab Guides -
I create my menus in Photoshop. Try this for a simple menu
1. Create background (duh)
2. Add text layer "play", rasterise
3. Duplicate text layer
4. Merge first text layer to background.
5. Save as PSD file
When you load this into DVD Lab Pro, the remaining text layer will become the subpicture for the Play menu choice. Link this to the start of your movie and you're done.
If you have multiple buttons, follow the same process, with each button having it's own layer in the PSD for subpictures. I have a series of actions I use which adjust the style prior to merging, and create the new layers.Read my blog here.
DVD Lab will keep the layers, but you only need one layer for each link. Any layer than is not linked to an asset will be merged by DVD Lab when you compile, while the linked layers will become subpictures. I prefer to do the merging in Photoshop.
Play around with it and see what suits you.Read my blog here.
DVDlab pro eating some legends
By bebado22 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 16:54 -
Reliability of DVDLab Pro 2
By Brainiac in forum Authoring (DVD)Replies: 2Last Post: 28th May 2009, 19:04 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
DVD-lab PRO 2 and Group Hotspots
By oz_surfer in forum Authoring (DVD)Replies: 3Last Post: 18th Oct 2008, 08:07 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 05:43
i wasnt able to finf. im new to this.
