  1. Hi,
    I have a PC integrated into my HiFi/DVD/Video equipment. My display device is a 29" TV set. I would like to find the more convenient user interface software taking into account that I do not use a PC monitor but a TV set.
    I have tested several programs but they are generally designed for PC monitors. In fact I use the Windows desktop carefully configurated (800x600, big size fonts, resized icons, .....).
    Does anybody knows a better option? Thanks in advance.
    Paco
  2. Any suggestion?
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    you haven't given much info to work with.
    what is you system, display card?
    what have you tried? what didn't you like?
    basics:
    ATI MMC
    BeyondTV
    SageTV
  4. Hi,
    My PC is a P-IV with an ATI-7000 VGA card. Only the S-video out is used for video output (no computer monitor, only TV set).
    My problem is that HTPC software often uses small fonts a other features not suitable for TV displaying.
    A big size plasma or LCD could be bought in future ..... but now, for my budget, the only big screen option is a 50 Hz 4:3 TV set
    What do you think is the best HTPC software option for this case?
    Bye
    Paco
  5. Member edDV's Avatar
    Mar 2004
    BeyondTV or SageTV would be a good start.
