  1. I just bought the Pinnacle AV/DV deluxe.
    I have used Pinnacle's products in the past and have always been happy with the results.
    Well, now I seem to be unable to capture anything with this new card. It is version 2 of the card/breakout box combo. I have installed the newest drivers and updates to all the software.
    When I try to capture, I get between 2 to 8 seconds and then it freezes. I tried AMCap, which is supplied as a testing tool and it captured for a longer time, but dropped frames like crazy.
    Does anyone have any experience with this card?
    Thanks,
    Mike
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Is that the one with the Firewire on it? That's card I believe that has issues capturing via firewire. Y
    You need to be more specific as to what your doing...
  3. It has a firewire port on the card, not the breakout box.
    I am trying to capture analog/ vcr tapes.
    So far, no improvements.
    Mike
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    What format are you capturing too?
  5. I am a big believer in mjpeg as a capture format, since each frame is independant. Then, after filtering or editing I go for the newer formats.
    he codec I am using is PICVideo. Version 2 comes with the card, but I already own version 3, so I am using version 3 (Pinnacle does not let me access the configuration, limiting me to simply a 1-100 quality scale.)
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    That's incorrect. http://www.digitalfaq.com/capture/avivsmpeg.htm
    MPEG capture requires a very fast machine or a hardware encoder. You have neither use AVI.
  7. I was referring to mJpeg, the motion vertion of jpeg compression, which is an AVI codec. Not mpeg, the "only say what changed" dvd codec.
    And by the way, I thought 2.4 Ghz was fast enough for realtime mpeg encoding. Most software specifies 1.6 Ghz or faster for realtime mpeg-2 encoding. I never use realtime mpeg because the results are NEVER as good as when a quality encoder is used on an AVI.
    But again, my question is if anyone knows how to get the analog portion to capture. I keep locking up at 2 to 8 seconds.
    Conversly, if I cannot get this working in a day or so, What would be another similar product?
    Here are my requirements:
    Video and Audio captured by the same card.
    AVI capture, not hardware mpeg capture.
    AVI with selectable codec NOT DV codec avi.
    Thanks again!!
    Mike
