How can I create chapter images with video playing in it with Adobe Encore DVD?
Please write down url adr. if u know about some good links with tutorials.
Results 1 to 12 of 12
Drop it like it's hot
I can only play it for 15 seconds, how can I change that?
Drop it like it's hot -
It will not work, The animated button is looping at 15 seconds
Settings:
Duration - 00;00;40;00
Loop Point - 00;00;00;00
Loop# [Forever]Drop it like it's hot -
From You Project Preview of DVD the area in red circle red or green color?
If its red like in current image, select "File" -> "Render Motion Menus"
The lamp is green, but the animation button is still looping at 15 seconds
wtf is wrong
First you have update to version 1.5.1.42735 :
http://download.adobe.com/pub/adobe/encore/win/1.x/encore151_updater.zip
But I think the update do not help You(I do not have any problem with motion bottons before update)
Just start NEW project(difrent name) with 2 default motion buttons for TEST and set loop duration more then 15 sec.
Do not change the default buttons just for test. -
When I go from Hold forever menu to Anitmated button menu (next to duration and loop point) the duration time will automatically show 15 sec. Can I turn off this kind of setting?
I am done.
I do not have any idea, why duration keep on 15 sec. even if you change
duration time to more.
Maybe somebody other have solution.
Bye.
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Bluray Authoring with Adobe Encore
By jrodefeld in forum Authoring (Blu-ray)Replies: 4Last Post: 12th Jun 2011, 20:06 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
