Hi
In order to convert DVD to VCD I use the following programs :
TMPGEnc DVD Author 1.6
VirtualDub 1.5.3
TMPGEnc 3.0 XPress
And my workflow is like this :
1. I extract the mpeg out of the DVD to my HD using TMPGEnc DVD Author 1.6
2. .with VirtualDub I take the audio from the movie and save as wav file. i do it because the audio is 48Khz and TMPGEnc 3.0 XPress wont except it.
with TMPGEnc 3.0 XPress
3. I convert the mpeg2 to VCD compliant file.
Now two things, this is long workflow…I just wondering if there is a way to make some shortcuts? And…using this workflow the audio in the VCD is very low….where I can boost it up?
S
https://www.videohelp.com/tools?tool=Eazy_VCD
This would be Easy , not the best way,Not sure what you are asking. -
im a biginner...i told you what im doing....i just asked if what im doing is the right way.
Best workflow from a Vegas prepared project to a DVD?
By Srivas in forum EditingReplies: 2Last Post: 5th Jan 2012, 00:39 -
good question about dvd chapters and workflow
By YOURCONNEXX in forum Authoring (DVD)Replies: 7Last Post: 18th Feb 2011, 17:32 -
VHS to DVD workflow
By robjv1 in forum RestorationReplies: 3Last Post: 26th Feb 2010, 10:59 -
AVCHD to DVD workflow advice
By petem23 in forum Video ConversionReplies: 3Last Post: 16th May 2009, 07:57 -
workflow question: capture to DVD
By rozeltf in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:32
