I read this guide: http://www.jonesgroup.net/media/dvdworkshoptwostepone.htm
and have one question now. I understand that this can be configured to not reencode DVD compliant files. I have a question about the AC3 part though. Since my source audio will not be AC3 (it will be PCM), is DVD WS2 smart enough to NOT encode the video along with the audio? Will it treat the two files completely separate?
No I don't think you can do that... I think it's a yes or no kind of setting you can't pick and choose. If there compliant there left as is PCM or AC3.
However If all your files are the same you can set the properties of your output to match the properties of the videos, change the audio to AC3 and it should only do the audio. -
Yes, in DVD WS 2.x, you have control over how to treat the Video and Audio separately. Assume both are compliant, you can still tell DVD WS 2.x to Convert the audio only, and leave the video alone.Originally Posted by fmctm1sw
In the EDIT step, select the VIDEO tab, and use the checkbox for "Convert to disc template" -- if you want to convert a compliant video stream to your new settings. Under the AUDIO tab, you have the same option to "Convert to disc template"George
DVD authoring question...
By mjl1297 in forum Authoring (DVD)Replies: 8Last Post: 12th Mar 2011, 11:26 -
dvd authoring speed question
By slaak in forum Authoring (DVD)Replies: 0Last Post: 25th Jan 2009, 14:14 -
dvd authoring question
By ht0160 in forum Authoring (DVD)Replies: 1Last Post: 7th Jul 2008, 17:52 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 03:40 -
New to dvd capturing/authoring… Question
By tygger in forum Authoring (DVD)Replies: 7Last Post: 18th Jun 2007, 14:17
