Is there a difference in quality if you burn a DVD -R regular burn or fast burn,both on the same record mode??? If there is,Is it so little that the naked eye can't see it??
What DVD recorder do you have, BTW?
By 'regular', do you mean in 'real time', as in the same time as the recorded content? If so, DON'T. You're re-encoding the video, BAD. If the content you recorded fits on the DVD at the recording quality you used originally, do NOT re-encode it, burn it 'high speed' onto the DVD.
I have the Sony Hx-900 w/HDD,,Yes i mean real time, . You say do not use real time?? Fast burn is better??
If you are changing the 'quality' setting of the content when you burn it to disc, then absolutely, you will be re-encoding the content. Even if you have something that only fills half the disc and you change the quality setting to fill the full disc, you are going to worsen the quality of the original recording.
There's ZERO reason to burn to the disc in real time, unless you HAVE to re-encode the content in order to get what you recorded to fit, in which case it'd be in real time. -
is the quality of re-encoding that bad? if you record something in XP to the hard drive and it turns out to be 1hr 20mins, and you do a real time FR to disc which will re-encode. will the quality suffer that greatly? or will it be similiar to an FR 1hr 20min recording from the tv broadcast to a dvd?
Getting a better quality burn
By brado09 in forum DVD RippingReplies: 6Last Post: 24th Apr 2009, 10:59 -
Check quality of burn
By amerifax in forum DVD RippingReplies: 8Last Post: 18th Mar 2009, 20:34 -
Quality reduction on Burn
By barkingcat in forum Authoring (DVD)Replies: 20Last Post: 24th Mar 2008, 07:58 -
My burner used to burn fast enough...but now it doesn't
By Auto Ford in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Nov 2007, 17:10 -
How to burn RMVB files to DVD so it will play on regular DVD player
By MithrasX16 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 05:53
