Hi guys:
I have a demo DVD I'm fixing up for myself and a friend who assembled it. It's about 25 short clips. I planned on demuxing the VOB's and then using Maestro, authoring the clips with chapter markers and a menu.
I ran into some VOB's that won't demux. I used dvddecrypter and set file length to none and decrypted the vob to my hard drive. I then used TMPGEnc mpeg tools to demux the VOB's. On a sample problem VOB, I have video, but no audio stream listed. I tried a default decrypt in file mode and instead of one VOB I got 5. In those 5, 4 reported as being audio streams, but none would open after demuxing.
Can someone help point me in the right direction? How can I demux this VOB so I can use it in Maestro as separate video and audio streams? Since it's demo I dont' want to decode and reencode the mpeg or ac3.
Thanks,
shorton
Have you tried just enabling stream processing in DVD Decrypter and using it to demux?
No, not specifically. But I will try. I'm not a decrypter expert, I tried the defaults, and then the way mentioned above. I'll see if I can figure out how to enable stream processing and see if it helps.
Thanks for the time to help, Scott -
sanjayk: Thanks, I'll give that a try, too. Help much appreciated. I'll report my progress back..
Followup for others seeking the solution in the future...
I had some issues with the ac3 files made by Vobedit. They wouldn't import to Maestro. See other thread "Media detection error" by me.
I used ReJig 0.5e and got the audio files out with it. I chose demux and the fix ac3 timecode option. The resulting files would import to Maestro AND had no lipsync error that I could see.
HTH,
Demuxing Problem
By jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 19:10 -
Demuxing DL problem
By calanda in forum Authoring (DVD)Replies: 9Last Post: 15th Feb 2010, 23:52 -
Demuxing question
By gouletjo in forum Authoring (DVD)Replies: 4Last Post: 15th Feb 2010, 23:18 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 17:04 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 21:39
