I have used TMPGEnc Plus 2.5 to convert dozens of movie files I've downloaded off the web into .M2V and .WAV files. I've run into one that TMPGEnc can't seem to handle though. Most of the files I've converted were .avi files, but I've been able to convert a couple of .mpg files too. Anyway, when I tried with this particular file, the audio file that's created is nothing but silence. I used the same settings I have for every other file I've tried to convert, but for some reason this time it won't work.
In this instance, I actually only want the audio. I don't intend to make a DVD movie out of it. I just want to burn the .wav file to a CD so I can listen to it in my car. Is there a different program I can use to extract just the audio? Any advice would be much appreciated. Thanks.
Extract it in virtualdub.
Audio, full processing.
File, Save .wavCheers, Jim
My DVDLab Guides -
Hey. Thanks for the reply. I actually tried VirtualDub and that didn't work. I got an error saying "No audio decrompressor could be found to decompress the source audio format". Any ideas?Originally Posted by reboot
Hello,
You could do it as mp3. Get lamemp3 and unzip it into your virtualdub directory. Than you can use any quality mp3 up to 320kb.
Try virtualdubmod, different than virtualdub.
Cheers, Jim
My DVDLab Guides
Extracting audio from a 3gp file
By berfles in forum AudioReplies: 2Last Post: 17th Nov 2011, 10:54 -
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Extracting Audio From MP4 File Help Please :(
By MyKool Buble in forum Video ConversionReplies: 5Last Post: 3rd Mar 2011, 12:36 -
Cannot open the MPG file after extracting with VOB2MPG 3.0 PRO
By shira in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 17th Jan 2010, 08:50 -
Extracting audio from RMVB file.
By capman21 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jul 2007, 02:00
