I can't get WinTV Go to work right with XP. It's installed properly, all the drivers (Microsoft approved) are there. But, when I try to capture (using vidcap or VirtualDub among others) I get a message that says "Video device already in use". I'm not running anything else on the computer.
According to Hauppauge's web site, WinTV Go is fully compatible with XP. I've already tried uninstalling and reinstalling all drivers and software.
Does anyone have an idea what's going on here? Thanks.
Just thought I would let you know that I had similar problems with my Win XP. Everytime I started to capture, the sound would just mute itself. As soon as I stopped capturing the sound would come right back. I downloaded the new driver off their website but it didnt help. Im just going to use my old computer with Win 98 to do my VCD's.
Boxingjunkie
Capture Lossless with WinTV-PVR-150
By rudolf016 in forum Capturing and VCRReplies: 50Last Post: 28th Feb 2012, 12:39 -
how to play Hauppauge WinTV v7 channels in windows media player/ wmplayer
By rahemeen in forum DVB / IPTVReplies: 17Last Post: 7th Feb 2011, 17:42 -
How to capture ATSC to .ts file with WinTV HVR-1250
By tgcujo in forum DVB / IPTVReplies: 11Last Post: 25th Aug 2010, 19:41 -
Video Capture with Wintv PVR 500
By radink in forum Capturing and VCRReplies: 3Last Post: 11th Aug 2007, 15:05 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
