Can I use an analog camcorder to stream live? Basically use my camcorder as a web cam?
Thanks,
JD
You would need a capture card that supports "video for windows". The other spec clue that works is "netmeeting compatible". Few cards or adapters do this, never assume it will work unless stated in the specs.
"video for windows" is now a legacy technology. Older cards are more likely to work. WDM is the new model but support for webcam mode was left out.
> tech answer http://www.nomadelectronics.com/VidCap/Capture%20using%20VFW/captureVFW.htm
http://www.ati.com/support/infobase/3749.html -
Thanks! Any particular card that you would recommend?
Also, if I have a s-video port on my camcorder and one on my video card would that work the same as a capture card? -
Originally Posted by JDCAM
I have several old obsolete cards and adapters that do it
Pinnacle DC-30plus
Osprey 50
etc.
Webcam use is not about hardware inputs, although you do need S-Video in, it is about the capture card drivers and how the card talks to Windows.
I should have answered, unless you are willing to get into the driver tech, the anwser is no. Fewer and fewer carture cards support VFW. -
I forgot to mention the other way to do it is to buy a webcam (Like the Intel Webcam pro) that have switchable video inputs on the webcam. These will interface your analog camcorder into VFW.
http://www.epinions.com/cmhd-Webcams-All-Intel
one like this
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4616&item=5165363245&rd=1&ssPageName=WDVW
you can get Windows XP update software from Intel for about $6
All of the above is about using your camcorder as a webcam or for streaming from webcam apps.
You can also use standard capture cards with software like Windows Media Encoder 9 to stream video either to a LAN or over the net.
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 06:14 -
Using DV Camcorder to Stream Live
By johnwenzel in forum Video Streaming DownloadingReplies: 3Last Post: 9th Sep 2009, 05:41 -
How to record video from camcorder and stream live simultaneously
By bnchs in forum Video Streaming DownloadingReplies: 2Last Post: 27th Aug 2009, 13:28 -
DVMixerPro 'soft toaster' live analog source motion artifacts
By cybertheque in forum Capturing and VCRReplies: 0Last Post: 10th Aug 2009, 05:04 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47
