I will be changing my capture process soon with some new equipment and I came across a capture question.
My system: Winxp; Geforce 5900nu graphics card; 1 gib ram
Capture process: Tv tuner/VCR -->Hauppauge 401 (s-video bt878); VFW drivers--> Vdub--> Huffy
With this setup I can only capture 640x480. I would like to cap or at least have the option to cap at 720x480 since the avi's will be going on dvd's. Is this a driver issue, vdub, or the capture card.
I would also like to throw out into the mix if my hauppauge should be upgraded . I prefer to capture to avi and will most likely be getting a standalone recorder eventually, so I do not technically need to capture to mpeg2. However, I would not mind being able to choose avi or mpeg2. I love flexibility! Is my Hauppauge outdated (chipset)? Any suggestions? Brands? Chipsets?
thanks
colt4523
Results 1 to 9 of 9
Hauppage PVR-250, 350 or 500 would all work.
Cheers, Jim
My DVDLab Guides -
I did not expect those Canopus ADVC 50 or 55 cards to be so expensive. I can get a standalone recorder for the same price.
I will give the BTWINCAP drivers a look. Hopefully it will let me cap at 720x480.
Is there any other decent cap software other then vdub. What do the majority of the people here use? -
What you get with Canopus ADVC 50/55 is a quality NTSC/PAL decoder to A/D DV stream conversion at very good quality (full DV 720x480, 4:1:1/4:2:0, 48Khz PCM audio, 25-35 Mbps stream) on par with a Sony DV camcorder.
The ADVC-100 also provides the return path with NTSC/PAL encoder.
Brooktree based boards are not in this class.
Ref: http://www.doom9.org/index.html?/capture/start.html -
Virtualdub never worked for me because there were always audio sync problems.
I am now using the excellent AVI_io which has a perfect audio sync. -
colt4523
You should try the BTWINCAP drivers, but only if has a 8x8 chipset. Make sure first. Whatever drivers you use make sure there for your chipset
You can tell what chipset by the model number.
If your Houppauge card is a BT or Conextant 8x8 (prefer 878a) and you deciede to get did of it, I'd be intrested.
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
TV capturing n Rippin using VduB
By SMChoice in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2009, 11:39 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50
