Have any of you had any issues backing up Band of Brothers Disc 1? I have tried a few times with this method with no avail.
MTR- dvd2oneX- burn.
Once I make a back up with MTR.. sometimes it gives me major trouble just looking in the VIDEO_TS folder... sticks up and sometimes makes the external drive freeze... this is the only backup that is giving me issues, and I've done tests... it doesn't seem to be the external drive. When I go to DVD2oneX it stops me after about 10 minutes and says it can't find a part and needs the entire disk to make a backup. This has happened every time I back up Bandof Brothers... any ideas??? any success stories?Thanks- FCPguy
Results 1 to 9 of 9
"What's a matter Colonel Sanders???? CHICKEN???!!!!
Warner Brothers is doing something on its HBO DVDs to annoy folks who copy them. Same sort of thing happens on disc 3 of season one of Six Feet Under.
know of any work around? If my sister ruins one more of my band of brothers dvd's I'm going to flip!!! She's a scratcher!
"What's a matter Colonel Sanders???? CHICKEN???!!!! -
Ok, I took a good look at all the files in my backup. The backup worked perfectly as far as a 7 gig rip. It is during the compression part that I am having problems with. Is this the same as the others? I can watch the disc perfectly on my mac and it seems to be running fine. I looked at the files ripped in compared to the original, and all the files are identical.
It is just driving me nuts. There doesn't seem to be a reason for this error. I've re-ripped it a couple times, with similar results. Maybe I need a newer version of DVD2oneX? Any tips guys?"What's a matter Colonel Sanders???? CHICKEN???!!!! -
What if you did a cell rip only in DTOX and ripped only the epsidoes? Would this disc play fine? I'm thinking it might
be similar to ArCCOS but in a reverse way as it would have
to be IFO centric, as ArCCOS wasn't around then?
Don't really know, kinda grasping at straws.
Most of my HBO stuff I recorded in through Canopus
and made my own DVDs from VHS--Kinda glad, but the
trade in time vs. outlay in cash ended up about even....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I surmise its something to do with how the dual layer break bit was set.Originally Posted by FCPguy
It must be doable somehow, since there are 4.4GB pre-shrunk rips available on the net ...
Try another shrinker? -
I'd bet cash those internet copies were ripped and compressed on a PC. I prefer an all-Mac solution to everything
trouble backing up dvds to external hard drive (on PC)
By duquesne in forum Newbie / General discussionsReplies: 4Last Post: 25th Dec 2010, 09:32 -
Hello I am having trouble backing up a dvd
By Seekyr in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2008, 12:14 -
Trouble backing up Mr Woodcock
By dor in forum DVD RippingReplies: 3Last Post: 18th Jan 2008, 14:18 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 01:38 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 21:34
