Hello all:
Does anyone know of a way to convert from .avi to .mpeg WITHOUT altering the content/quality of the .avi?
I do not mind the fact that i would need ALOT of Cd's to make a VCD; the issue i'm having is a HUGE amount of pixelation in the converstion (i'm using both TMPEGENC and XINGTECH).
Joe
You wanna WHAT!!!!!!!
MPEG is a compression codec plain and simple.
Any conversion from raw .AVI (i assume not Divx) to ,say Mpeg2, will result is 'data' loss.
You best solution, if you wish to preserve quality of original is to reincode in MPEG2 at a constant bitrate between 6 to 9 MB/sec. The higher the better of course. Do some tests to see if you can see any difference.
What is the original source material??? This will impact the decision for the compression codec to use.
For my (PAL)home VHS video i capture at 384*576*25fps then encode MPEG1 at 384*288 at a CQ bitrate of 2400 in TMPEGEnc.
This seems to be the sweet spot for MPEG1. MPEG2 at this bitrate is worse (this will start a few arguements) due to way it encodes. I now have master disks and can if i wish later make standard VCD.
If you want to make standard VCD then tough . YOU WILL GET PIXELATION. Try perhaps (X)VCD if your standalone DVD will support it. -
I'm assuming that you want to transcode an encoded avi file to mpeg. Unfortunately as they use different compression methods you do have to re-encode.
However to solve pixellation try adding smoothing filters (temporal and spatial), incresing bitrate of your target file and adding macroblock smoothers.
Note if your going from a divX the quality will not be very good, unfirtunate I know but it just seems to be the way it is. -
Thanks for the help...
This should get me started...
I'm getting a new situation with conversion (but that will be another topic post!)
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 21:42 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 09:18 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 23:13
