I have many movies on my PC that have AC3 or DTS sound that play fine through my speakers with AC3Filter. I also have a sony home theatre that allows me to input sound from an external source to play through my 5 speakers. The only problem is that it will only accept input via a normal stereo left/right cable ie. it doesn't have spdif in. Is there some way I can setup my movies so that the sound is output through all 5 speakers? My audio reciever can output Pro Logic I & II.
Thanx
If your only input option is stereo, then your receiver will have to create the center and surround channels, which it should be able to do just fine.
Google is your Friend -
With simple L and R audio, you will not get true DD audio. Your receiver will probably shift the signal to something like Pro Logic if you so choose. As far as 5.1, you are out of luck.
How to reverse stereo channels for a moive file?
By paytonlow in forum AudioReplies: 7Last Post: 18th Sep 2010, 12:31 -
How am I getting these cable channels free?
By vid83 in forum Off topicReplies: 11Last Post: 20th Mar 2009, 18:43 -
Some Cable channels suddenly won't come in
By chimneysweep in forum DVB / IPTVReplies: 21Last Post: 6th Feb 2008, 14:26 -
Removing one of the Stereo channels In Premiere Pro 2.0
By HarveyCee in forum EditingReplies: 7Last Post: 21st Oct 2007, 15:18 -
Receiving cable channels
By kanamaster in forum Off topicReplies: 2Last Post: 6th Aug 2007, 22:28
