I had a phone call yesterday from a mate saying that "my pc switches off when encoding in DVDShrink" after a five min conversation it would appear that his PC encodes about 70 - 80% then the entire thing switches off. Not a reboot or a BSOD just off, dead.
I'm already sure that its his PSU and not an overheating issue, but I thought I'd gather some opinions here before venturing over to his house with a different PSU.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I would look to thermal issues first with a problem like that as it sounds like it may be time enough to max out an OEM heatsinks thermal efficiency. But if you don't think it's related to heat then the PSU can certainly fold the system if it gets drawn on too hard for an extended period of time. No easy way to stress-test a PSU for most of us so the solution is to put a better one in and see if that fixes it. May need to check the system specs and make sure the one that's in there is even rated for all the hardware.
FB-DIMM are the real cause of global warming -
It may well be a heat issue but all the overheat issues I've ever had or seen simply caused a reboot rather than a shutdown. I'm hoping its a PSU problem as I have two spares.Originally Posted by rallynavvie
It never was, but of course now he has a new MB which I forgot about.Originally Posted by Soopafresh
Must check that with him.
If you think it's a heat issue, remove the cover and see if you can duplicate the error.
PSU Question
By SE14man in forum ComputerReplies: 11Last Post: 13th Jul 2011, 09:07 -
Dodgy VOBs misreporting length
By Joolz2020 in forum Newbie / General discussionsReplies: 12Last Post: 13th Oct 2010, 18:43 -
No 'Right Audio' and dodgy quality
By xxJackMBxx in forum Capturing and VCRReplies: 29Last Post: 21st Sep 2009, 11:34 -
Dodgy Sales Guy
By oz_surfer in forum ComputerReplies: 9Last Post: 6th Nov 2008, 19:46 -
Dodgy picture ?
By plog1976 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Dec 2007, 11:39
