i have a bunch of extracted divx wav files in 48hz format and i need to get it down to 44 hz.. any suggestions?
okay, so I'm using smpx.. the default quality setting is 20.. is this suitable? i can slide it all the way up to 100.. but i don't know... is 20 normal?
20 is fine, 100 takes a very very long time (my P3 750 1.5 hour movie = 3hours +).
Note that SCMPX does a good job, but SSRC is faster. I tend to use ssrc and if that fails try SCMPX (plus it looks really nasty). -
is there a guide to using ssrc with azidlame gui? i don't understand how.. ?? thx for the help btw!
Here's a quick one for you:
-Open GUI> press SSRC button (right, over batch mode)
-At the top are three boxes for file locations, press the open folder button at the top and browse to where SSRC is, the next one is your input file to browse to that, the one after that is output choose a name and location for your save.
-Set sampling rate to 44100
-Tick perform 2 pass encoding
-Click convert wav
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 23:18 -
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 09:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 18:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 09:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 02:09
