This is something I really aughtta know, but apparently I missed this particular topic in my billions of computer installs, reworks, upgrades. Wasn't sure where to post it, except here.
I'm seeking out the perfect capture system, and it seems I can do everything I require using the Huffy codec. Well, as you all know, the Huffy codec is lossless. Lossless means uncompressed. Uncompressed means I NEED HARD DRIVE SPACE!
I'm looking for an 80-100GB sized drive to capture on, and have at least a couple hours worth at a time.
To make a long story short: I'd like to swap my drives around. I want to eliminate one drive, copy its contents to another hard drive. The catch is that both hard drives I have, Windows is installed on them. Can I somehow copy the WHOLE contents of a drive to another, including the Windows install?
Here's what I have now:
C: Windows XP, 12GB drive
D: Windows 2000, 40GB drive
X: (new drive), 80+ GB
What I want to do:
C: (sell)
D: Old C: Contents (XP)
X: Old D: Contents (2000)
Can a whole drive be moved to another of different size/partition, yet preserve a Windows boot? Or even dual-boot?
Thanks...
here's what i would do since my experiance in PC's is limited. Back-up everything. Format, then re-install....i do this at least once a month.. clean slate for everything to work with.....takes me about 2 hours topps.....
hard drives
By Willy5157 in forum ComputerReplies: 7Last Post: 23rd Oct 2009, 04:16 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 18:00 -
2 hard drives
By danl_9x in forum ComputerReplies: 8Last Post: 8th Feb 2009, 22:55 -
Hard Drives
By jason in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 11:50 -
Better speeds using 2 hard drives?
By kelemvor in forum DVD RippingReplies: 22Last Post: 15th Jun 2007, 15:35
