Have 2 x 700meg Divx 3 low motion files (Gspot) which I want to join and convert to MPEG2 to burn a DVD. What is the best way to do this ?
Also the sound volume is very low on these files, how do I correct this ?
There are 10 kinds of people in this world. Those that understand binary...
Originally Posted by Davi0There are 10 kinds of people in this world. Those that understand binary...
You can increase the volume in Virtual dub. Click audio, volume. You have to use "full processing mode" to do this. Check the software you are using to encode to mpeg or to Author the dvd. Some software will allow you to do this without doing the extra step.
Ok now how about joining the 2 files, do I join before or after encoding to MPEG and what program is recommended.
If you're gonna join them before use Virtualdub (avi).
Myself I encode to mpeg then use my authoring program to add the files. Tmpgenc dvd author is easy to use and does a really good job.
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08 -
Join Avi (xvid) files together
By SpyJoe in forum EditingReplies: 11Last Post: 26th Aug 2009, 17:44 -
Advise on best conversion proceedures..
By levick in forum Video ConversionReplies: 2Last Post: 24th Apr 2008, 09:22 -
I Can't Join 2 XviD Videos together!
By Nitro89 in forum EditingReplies: 10Last Post: 26th Jun 2007, 15:08 -
DVD->MP4 conversion quality problems - Need your advise
By amir77a in forum DVD RippingReplies: 6Last Post: 1st Jun 2007, 02:27
