Svcd2dvd v2 seems to create a slight problem on my philips dvd player, when there is a chapter point the movie pauses, then skips forwards to catch up. This only happens with material from SVCD source and only on my philips player, and happens regardless of what program is used to create the svcd mpeg, the same mpegs can be used in dvd-lab to create flawless svcd-dvd's. The chapter problem also doesnt happen on every chapter, I suspect it may be something to do with the GOP structure, and the frame in which the chapter is inserted, however I am no expert so I could be wrong. If you want me to upload a log file and a set of Vobs for you to look at chrissyboy I will, just let me know. I have scanned through this forum and their are a few posts regarding similar problems, many of which have gone unanswered, so I cant be the only one with this problem.
Results 1 to 9 of 9
Sure upload the files. Is this at the point where mpg files change ot chapter points within an mpeg?
its at the chapter points, where the mpegs change it is usually fine (unless there is alread a slight overlap/gap). I'll upload them tonight for you to look at.
ok. Thanks. Could do with the DVDLab versions too if poss. And original mpeg.
I'm uploading the files now, they are in a folder called "philipschapterprob" IT checked them on my dvd player again, as not all chapters have the problem. With SVCD2DVD the problem chapters are 5,8,9,10. I tried to put the chapters at the points with dvd-lab, and there are slight (not as bad as svcd2dvd) probs with chapters 9,10 only. Could take a while to upload tho as its 1.6gig in total.
Ok. Thanks for this i will investigate. Sorry about the size!
All uploaded now, except original mpeg, although as the same thing happens with all svcd mpegs It should'nt make too much difference, I will upload it if you need it tho. As i said in the above post not all chapters have the problem, and by attemting to recreate the exact chapter points with dvd-lab I got problems on chapters 9,10 also, although not nearly as bad.
OK just got a Philips DVD player 642/37 divx player
ive been useing svcd2dvd 1/2 and rc3 and have played all the discs i made useing this program on this philips player
i think its your player thats screwed up
have you taken the top off and cleaned the laser head with a cotton bud and rubing alchol
might just be dirt -
Originally Posted by britincanada
Cheap Blu-Ray Player that does it all....like Philips Dvd Players do?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 52Last Post: 29th Apr 2011, 11:42 -
Philips BD players (US) Question?
By BluFan80 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Nov 2010, 23:19 -
Max Bitrates for USB content on Philips DVD Players
By GrayStrickland in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Mar 2009, 18:18 -
Do all Philips DVD players break over time?
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Mar 2009, 12:30 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 09:06
