Hi,
MY laptop(HP COMPAQ nx 9010 having xp) does not shutdown . it gives the message -> windows shutting down, but no response. i have to manually press the on/off button for some seconds and shut it down
any ideas on why this is happening ?
Santosh
Results 1 to 9 of 9
How long are you giving it to shutdown before you manually hit the power button?
normally it used to take 30/45 secs to shutdown
but now even after 1/2/3/5 minutes it is not shutting down
santosh -
You've probably got something running that Windows can't shut down. I'm assuming XP since you didn't fill out your computer profile. Open Task Manager and see what is running prior to shutdown.
ok..i will try and let u know
and one more thing is when i press ctrl alt del, only the processes are displayed....the full window is not coming (no file,options,view,help options) and no applications/process/performance and networking)
i only get the list of processess and i have to kill this taskmgr
why this is happening ? any set-up to be done ?
santosh -
You could type in msconfig from the run command and list what is running. We could then tell you what to shut-off.
ok...i will do this and let u know
but what is the solution for the ctrl-alt-del ? for me to see the full menu for this task manager ? why this is showing only the process to me and not the full task manager features/menus ?
santosh -
NO
i have not done anything like this
i just installed the broadcom adapter..for wireless connection..that is it
santosh
Is there a way on how to shutdown xvid4psp after encoding?
By mark63534 in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2011, 00:05 -
Laptop shutdown problem
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2011, 13:27 -
Handbrake shutdown switch
By leghorn in forum Video ConversionReplies: 1Last Post: 16th Mar 2010, 08:54 -
ConvertX2DVD shutdown
By smalld in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 21:27 -
Automatic Shutdown
By borisblavasky in forum ComputerReplies: 10Last Post: 12th Jun 2007, 15:13
