I keep seeing people talk about frames dropping. Does this mean that as your captureing some frames just disappear (causing out of sync sound and video?). LMK
thanks
Guest
Well they don't actually disappear as they were never created.
For example if you are using PAL to capture a video feed it should capture 25 frames per second. Now if it only captures 24 per second, you've lost or as video techies say, dropped a frame. The more frames you drop the more choppy the video feed would become, as your player would still play 25 frames per second.
OK?
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
Newbie needs explanation on film frame rate
By holeepassion in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2008, 01:29 -
Newbie frame/ field - capture both interlaced fields
By peter bradbeer in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 8th Feb 2008, 15:36
