Results 1 to 30 of 43
  1. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Will be posting scans of how these burn on my NEC 3500, and a NEC 2500. Will do DVDInfo, CDSpeed, and KProbe (Using an 832S).
    These are on sale right now for $7.95 per 25. They are not advertised, nor packaged as printable, but they are indeed white inkjet printable. I've never seen a price like this for printable media... Had O.K. luck with CMC +R in the past..(While CMC -R has been completely craptastic for me).
    Scans soon.
    Seth
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  2. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    DVD Info. This disc was burned at 8x.
    Archived DVD Scans
  3. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Archived DVD Scans
  4. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Wow...just a note...(Running K-Probe now..)
    Just printed one of these discs.
    One word: "Woah!"
    These easily have one of, if not *THE* best printing quality surface I've ever used, and I've used quite a bit of printable media. Awesome!
    Archived DVD Scans
  5. Hmm, I wonder what that was that you burned on that disc there.... :P
  6. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Hmm...seems to be an odd spike. will watch this to see if it skips a bit later where the spike is. Also will do another burn, and re-scan it, and post back with the results, to see if it spikes in the same spot, or at all.
    Archived DVD Scans
  7. Are these the matte printables or the smooth ones like Prodisc?
  8. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    These feel rough to the touch..not smooth like Prodisc.
    Archived DVD Scans
  9. Great scan minus the one spike, although that's a pretty minor spike in reality. PI 20 PIF 7 is far from being a problem area, just not as pretty as could be :P
  10. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    YEH, A little rough to the touch, def. unlike prodiscs. Wish they were hubbies, but still a nice surprise to get these. Bizzare how tdk didnt package these as inkjet printables, seems they were put together kinda helter skelter as the 25 pack looks like it normaly hold maybe 30 to 35 or so.
  11. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Yeah...mine had two of the little foam things on the top, not the usual one. Opening a -R pack in a minute to see if it has 2 as well, or just one.
    Archived DVD Scans
  12. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Heh! The -R, are printable as well. Will post media ID as soon as my current burn is done.
    The -R had no little foam thigns on the top, and the spindle appears completely full.
    Edit: The DVD-R are TTG02. Will start a seperate thread soon with scans from these discs.
    Archived DVD Scans
  13. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    I 20:01:34 Source File: E:\GIRL_INTERUPTED.ISO
    I 20:01:34 Source File Sectors: 2,287,584 (MODE1/2048)
    I 20:01:34 Source File Size: 4,684,972,032 bytes
    I 20:01:34 Destination Device: [1:0:0] _NEC DVD_RW ND-3500AG 2.18 (D:) (ATA)
    I 20:01:34 Destination Media Type: DVD+R (Disc ID: CMC MAG-E01-00) (Speeds: 2.4x, 4x, 6x, 8x, 12x)
    I 20:01:34 Destination Media Sectors: 2,295,104
    I 20:01:34 Write Mode: DVD
    I 20:01:34 Write Speed: 8x
    I 20:01:34 Test Mode: No
    I 20:01:34 BURN-Proof: Enabled
    I 20:01:34 Filling Buffer...
    I 20:01:35 Writing LeadIn...
    I 20:01:53 Writing Image...
    I 20:10:58 Synchronising Cache...
    I 20:10:59 Closing Track...
    I 20:11:12 Finalising Disc...
    I 20:11:25 Operation Successfully Completed! - Duration: 00:09:50
    I 20:11:25 Average Write Rate: 8,394 KB/s (6.1x) - Maximum Write Rate: 11,478 KB/s (8.3x)
    I 20:11:25 Cycling Tray before Verify...
    I 20:11:41 Operation Started!
    I 20:11:41 Source Device: [1:0:0] _NEC DVD_RW ND-3500AG 2.18 (D:) (ATA)
    I 20:11:41 Source Media Type: DVD+R (Disc ID: CMC MAG-E01-00) (Speeds: 2.4x, 4x, 6x, 8x, 12x)
    I 20:11:41 Verifying Sectors...
    I 20:16:42 Operation Successfully Completed! - Duration: 00:05:01
    I 20:16:43 Average Verify Rate: 15,199 KB/s (11.0x) - Maximum Verify Rate: 21,991 KB/s (15.9x)
    Archived DVD Scans
  14. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    ewee, I cant post a scan of the disc. LOL
  15. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Jaxx...I'll scan both the +R and -R. Give me one sec. I'll post the scans.
    Yours have a white hub? That's odd...the hubs on both of mine are branded, and clear, heh.
    Seth
    Archived DVD Scans
  16. Member jaxxboss's Avatar
    Apr 2003
    JAX, FL
    yeah, mine have the TDK mark and DVD+R below, but the hub is clear, its just hard to see that since the scan background is white as well .
  17. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Archived DVD Scans
  18. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Here's another KProbe burned at 8x. Looks like the spike in the first was just a random thing.
    Here it is.
    Archived DVD Scans
    I bought out an entire store of DVD-R. So far, all has looked good, scanned well.
  20. Here's a couple of scans, Teon branded CMC E01. BTW, Benq tests PIF differently than Liteon drives, a PIF spike of 16 on a Benq is essentially an equal to a spike of 4 on a Liteon. It should be pointed out so people don't judge the PIF to be high.
    This was an 8x burn on my Benq 822 (B3IC):
    This is an 8x burn on my NEC 2500 (1.07v2b5), burned and scanned just a few minutes ago :P :
    Very good discs, never a coaster as usual with my CMC discs, despite some claims of 'garbage landfill material with greater than 50% coasters'
  21. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Heh....all the DVD-R (Speaking of CMC, not the TDK TTG01's), I've ever burned have been coasters passed the 3.5gb mark. i'm pretty fond of the +R CMC, but -R, i avoid like the plague.
    And Smurf, I bought 600 -R, and 150 +R of the TDK's today. Figured I'd stock up while the in-store prices were actually cheaper than the internet prices, heh.
    Archived DVD Scans
  22. CMC- AE1's -R are not that bad.....
  23. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Here is another scan. This one is burned at 4x, on a NEC2500. Will post an 8x burn on the NEC soon.
    Archived DVD Scans
  24. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Heh...heres the scan (of the oen burned on 3500 @ 8x) using CD speed.
    Archived DVD Scans
  25. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    Archived DVD Scans
  26. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    From the disc burned @ 12x previously.
    Archived DVD Scans
  27. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    KProbe@12x
    Couple of spikes, but I checked playback, in a cheap DVD player, and my PS2. It plays flawlessly. However, I wouldnt trust a 12x burn with this scan on a DVD that was critical...call me paranoid.
    Archived DVD Scans
  28. Burned with my BenQ 1620 at 12x using strat swap of MCC 004.
    I may get a few more of these.
  29. Video Restorer lordsmurf's Avatar
    Smart man.
