But seriously, folks...
I have some 700 MB or so .avi's that I would like to encode to 800MB or less .mp3s so that I can burn them as VCD's. But it seems that every time I try it they come out way too big! Like 1 or 2 GB too big! So what is the best way to decrease the file size so that it will fit on one CDR (up to 800MB)? I know I will probably have to sacrifice some quality, not too much I hope, but I'd like to fit the movie(s) onto one CD each. But, if there is going to be a big rediction in quality, how can I span it to two CDR's?
Thanks in advance to your advice to my newbile questions...
I am afraid, you will loose a lot of quality if you convert a 700 MB avi (DivX I guess?) to a 800 MB MPEG-1.
Use a bitrate calculator from the tool section.
You will end with a XVCD, that is off-standard and that's why you may have playback problems with few dvd players.
I suggest to use 2 CD's. Have a look at Sefy's guide, how to use TMPG's source range or split the MPEG afterwards.
.mov size issue
By devdev in forum MacReplies: 7Last Post: 20th Apr 2012, 09:29 -
XVID4PSP and target file size issue,
By bugsboney in forum Video ConversionReplies: 4Last Post: 11th Nov 2009, 17:24 -
SATA HDD size reporting issue
By Noahtuck in forum ComputerReplies: 10Last Post: 30th Jun 2009, 20:31 -
Strange audio size issue.
By mijman in forum DVD RippingReplies: 1Last Post: 16th Jan 2008, 07:42 -
DVD display size issue
By tanshul22 in forum Software PlayingReplies: 1Last Post: 28th Nov 2007, 19:13
