I have Shrek.avi and would like to encode it to .mpg and burn on a VCD. Below are the properties for the file but every template I use in TMPGEnc fails ("An error occurred when audio was encoded". What settings should I use (no template)?
File Size: 701MB
Audio:
Audio format: MPEG Layer-3
Average data rate: 15.999 Kb/sec
Sample Rate: 48.00 kHz
Channels: 2 (Stereo)
Video:
Stream name: Shrek.avi Video #1
Frame Width: 512 pixels
Frame height: 384 pixels
Play length: 5279.70 seconds
Frame count: 126571
Frame rate: 23.976 frames/second
Data rate: 136.20 Kb/sec
Video Sample size: 24 bit
Video compression: DIVXMPG4 V3
If there's a pro out there that can help out a newbie here and give me the correct settings to get this file to a 800 MB or so .mpg I'd greatly appreciate it!
you need to make a wav file of the audio.try virtual dub.
1. in VB go to file and open video file.
2.next go to audio and click full processing mode.
3.go back to file and select save wav, choose file name and
click save.
use the wav file as your audio source in tmpge.
if the frame rate is:
23fps use ntsc film template
25fps use pal template
29fps use ntsc template -
blarb,
I'm sort of a newbie too. I'm no pro but I'm guessing you DVD-rip your clip, right? If so, go here for your instructions:
http://www.vcdhelp.com/tmpgenc.htm
If my guess it correct (DVD-rip) then you'll need a Codec and the above site will have it all for you
Look through the How To section and the forum first, to see if your question could be answer. That way, you don't need for your post reply. Good Luck, Jordan
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
HCEncoder settings
By leghorn in forum Video ConversionReplies: 2Last Post: 24th Sep 2009, 10:16 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 09:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 15:20
