  1. i was wondering if it is possible to add SRT subtitles when encoding with mainconcept via ffdshow or directvobsub. its possible with tmpeg, but no other encoder, or?
    if it is possible with mainconcept as i read already, can anybody plz let me know how?
    thx
    Dec 2004
    Australia
    ffdshow should work fine. Yep, tested it here and it works fine, just make sure that allow output format changes during playback is not enabled.
    Directvobsub doesn't seem to work. At least not here.
  3. maybe thats the problem.
    can you let me know where this option is? i couldnt find it, wheather in mainc. nor ffdshow.
    thx a lot...
    Dec 2004
    Australia
    It is in ffdshow but from recollection only in newer builds, like the last 2 months or so. It is under output. With it enabled Mainconcept would not use dshow for me. AVI's were opened in avi mode or if that was disabled, not at all.
