If a mpeg capture(or recording from dvd recorder) is at 720 x 480 resolution and , say , 4000 kbs bit rate, would re-encoding it to a higher bitrate , better the image, thinking of a 135 min recording that has edited out the commercials as an example.
Results 1 to 9 of 9
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
No. Every (re)encode further deteriorates the video quality.
/Mats -
Re-encoding it to a high bit rate would not improve the image at all. It would simply make the file bigger, and thereby increase the possibility of burn errors.
It's not the size of the file that matters...
It's the quality of that file. -
If you had an original file that was of a higher bitrate, it would work, say DV-AVI or higher MPG.
It's already been said, but you can't make more from what you got. Kind of like tryingf to make one dollar "better" by exchanging it for 100 pennies. -
But in this case, there's even a fee, so you'll end up with 95 pennies (at the very best).Originally Posted by Supreme2k
/Mats -
Thanks everyone, I did do a test, a dvd recording at 352 x 480 @ 9558 kps, and re=encoded it using tmpgenc at 720 x 480 and it came out looking slightly more fuzzy.
I guess that the only way would be putting the original through hardware processing?PAL/NTSC problem solver.
What do you mean by original?Originally Posted by victoriabears
Anyway, there are 2 reasons why your reencode looks more fuzzy. First, it's reencoded, which at the very best (given enough bitrate) should go unnoticed, but in practice will lower the quality. Then, and in this case probably the main culprit, you've resized up which should be avoided.
But your test doesn't match your original question about reencoding a "high res" low bitrate video to a "high res" high bitrate video - you've reencoded a "low res" high bitrate video to "high res" unknown (high?) bitrate video.
Using hardware or software processing doesn't affect this simple principle: Resizing and/or reencoding can never improve quality.
/Mats
Excel basic question
By alintatoc in forum ComputerReplies: 2Last Post: 8th Dec 2011, 08:46 -
Basic video projector question
By jbaugh in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2009, 01:58 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 11:04 -
Basic FAVC Question
By Maikeru-sama in forum Authoring (DVD)Replies: 4Last Post: 10th May 2008, 09:56 -
Very Basic Authoring Question
By Seeker47 in forum Authoring (DVD)Replies: 7Last Post: 10th Jun 2007, 20:24
