I have a 411S that I put in a Bytecc external case. The case has USB and Firewire connections.
My computer at work is a Plll 700 with 256mb ram running Win 98SE. The USB is 1.1. When I connect to my work computer and play a DVD, I get sound but no picture. This is with both Power DVD and Win DVD.
Is the USB 1.1 the reason for no picture? If so, is there a solution other than installing a USB 2.0 PCI card?
Herman![]()
I would not doubt it one bit that the problem is you have a USB 2.0 case and a 1.1 port. Although USB 2.0 is backwards compatible you will have MAJOR transfer rate issues. The machine you are wanting to play on might be alittle slow for USB 2.0 but you could try a card you never know.
The real answer lies in completely understanding the question!
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 21:58 -
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 16:28 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 12:05 -
change hd in liteon 5025
By DENAR in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Sep 2007, 12:47 -
LiteOn HD-A760GX opinions.
By aqtivator in forum DVD & Blu-ray RecordersReplies: 5Last Post: 9th Jun 2007, 18:01
