  1. hey
    have been using this program for ages and ages,,
    mainly to rip ac3 audio from avi files for converting to dvds,
    anyways, i do the usual,
    1, load the avi,.
    2, go to streams menu, stream list
    3, highlight the stream, click demux and save it,
    then a little window would come up about the audio rip information as it was ripping/saving it,
    but now when i do it, i click the save button, and it just goes straight back to the stream window
    without popping up that little window and doesnt save anything,
    ive also tried too
    get a later version, still the same, get the same version, same,, restart windows,. etc etc,, same same same,,
    seems a bit weird coz you just unzip it to a dir, no installation,
    i was doing about 12 files, and it happened on the last one,
    i may have canceled it or started a new one half way thru one that was running, but i dont see how that would matter if i was using a fresh one in a different dir,,
    i tried doing some of the files i know it works on, on all the ones i downloaded, still the same,
    any ideas??? got me farrrrrrrrked
    or any suggestions for another ac3 ripper??
    thanks
    Dec 2004
    Australia
    Try AVIMuxGUI.
  3. thanks man
    works great
