I'm using Premiere 6.0 with the BBmpeg plugin to create mpeg2 video in PAL format, which Nero then burns to PAL DVD for me.
This works fine, except sometimes BBmpeg has problems multiplexing the video and audio stream (.mp2 & .m2v) - it always tells you if there's been a problem which is good, but I can't find a way around it. I need a separate multiplexer !!
Or alternatively to know some better settings for BBmpeg... Frustratingly Nero will not take separate video and audio streams, so I must have a final .mpg movie in order to create the DVD
All help appreciated ...
Thats a good one.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Ts Muxer Blues
By romanticwarrior in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Dec 2010, 08:17 -
H.264 encoder with TS muxer
By kary.sharma in forum Video ConversionReplies: 1Last Post: 30th Dec 2008, 02:35 -
Resolution with ts muxer ??
By bobotheclown in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Nov 2008, 17:42 -
menc muxer problem ?
By Ahmed28 in forum Newbie / General discussionsReplies: 0Last Post: 10th Nov 2008, 06:27 -
My Xbox died, can someone recommend a standalone player?
By kdoggy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 19:29
