Chrissyboy,
Firstly, let me congratulate you on a superb peice of work in SVCD2DVD, it truly takes all the effort out of backing up your dvd's.
I have a query. My brother has a surround sound system that has digital coax cables running to his DVD player. I gave him a disk to try. We couldn't hear any sound?? Yet when we tried it on the tv in his other room (no digital coax cables), it was fine. I encoded the disk with normal mpeg audio. For his would I have to use AC3 encoding?
Any DVD with digital dolby surround sound plays fine on that system. Thats the only reason we could figure there was no sound present?
Well both mpa & AC3 are 2 channel if produced by SVCD2DVD. If you have 5.1 AC3 AVI assets then the 5.1 audio is maintained in the DVD..... That is all I know for certain.
I don't have a surround system but i would assume that the there must be some sort of way to handle non 5.1 audio. Maybe someone who has such equipment could comment. Maybe do a test DVD with AC3 to see if that helps too.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
check the settings on his dvd player, it may be set to only output Dolby digital signals, try setting it to PCM or something similar. I had a dvd player with exactly the same problem a while ago.
Coax cable splitter question
By txmt in forum Newbie / General discussionsReplies: 9Last Post: 17th Sep 2011, 22:06 -
TOSHIBA D-R7. Problem with quality of coax cable.
By caddyfleet in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Feb 2010, 19:01 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
Thin or flat coax cable....does it work ok?
By hygieneboy in forum Off topicReplies: 4Last Post: 29th Aug 2009, 21:28 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 08:06
