I am confused as to what speed they are rated at.... for example, my amd processor is a 1800. Is that 1.8 ghz or the 1.53 ghz my comp reads?
AMD Athlon XP 1800+, MSI 6712, Nvidia Geforce2 MX 400, 512 DDR, Maxtor 80GB HD, Sony DRU-710A, Hitachi GD-5000 DVD-ROM, WinXP SP2
1.53 GHz
1800 is a PR (public relations) value which is supposed to indicate it is similar in performance to a 1.8 GHz Pentium 4 processor.
Regards.Michael Tam
w: Morsels of Evidence -
They mean to say that their 1.53GHz CPU will match up with a 1.8GHz P4 in most cases, although I bet you the 1.8GHz P4 will leave it standing with video encoding and the 1.53GHz AMD will blow the 1.8GHz P4 out the water with gaming and unpredictable tasks.
It is confusing how processors should be compared nowadays, isn't it?
If you are after more speed and don't mind taking a little risk, you could overclock that CPU and gain more power. See my signature.
Cobra -
Take a look here : http://www6.tomshardware.com/cpu/20050202/sempron-09.html
then compare with the money you should pay for a platform, please...
Should I be so crazy to go with Pentium just for a label to stick on my computer that says "Tampax Inside" ?
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 18:39 -
the new AMD "Fusion" processors are out
By deadrats in forum ComputerReplies: 2Last Post: 2nd Jul 2011, 20:27 -
Does Final Cut Pro not support AMD processors?
By jeanpave in forum EditingReplies: 8Last Post: 27th Sep 2010, 03:03 -
AMD Phenom X4 9500 vs AMD Phenom II X3 710
By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 20:03 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 10:24
