  1. I have the Lite-On LVW 5101 desktop DVD Recorder I purchased from Samsclub. I downloaded the firmware update and followed directions on burning to cd disc and finallized it as told. But my liteon recorder does not reconize the disc.. I had my son do the same as I did using his burning program..but same results that I got. I hope someone is able to help me with this problem.
    Thanks,
    twowild4tv
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Thanks,
    twowild4tv
    What burning software did you use to burn the cd? The disc has to be burned in cdrom iso mode.
  3. I used recordnow and also tryed burn4 free. They both are set to finalize the disc like the update said.
    Thank you for your reply,
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    try using NERO BURN to burn. they have a trial you could download.
  5. Thank you I will give this a try
    Feb 2007
    Canada
    i hav liteon lvw 5101 since begin clock goes too fast,but after 1 yr on I get a big problem ; If I record onto +/-R disc & a week later try to record more since 1/2 disc empty when i put into recoreder it will not reconize disc ,recorder says blank disc even data is on disc ? I am trying to find the update of firmware but no luck on liteon site? where to get update plz help
  7. I had to search the web, but finally found the site....
    http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=75
    If you just bought your Lite-on you should take it back and get your money back...it is a piece of junk...mine died a few months after I bought it...and from many other reviews on Lite-on they agree with me...Well good luck with yours if you keep it, I really do wish you the best...I bought a Panasonic and love it and have had it for a couple years now.
  8. bobjohal
    If the unit was working ok before and now does not, why do you feel a firmware upgrade would correct it
    Go Here
    http://www.pumapeople.com/liteon/
    Select; - - US LVW-5101 --Firmware
    Download the file from this site
    Note the instruction .txt file --- [check it]
    Download the file from the site given by [twowild4tv] and compare them
    Liteon has done some weird things with firmware
