I upgraded the firmware on my LDW-411S and when I did, I can no longer "Backup!" DVDs; the encoding fails. of course, i dont have the old firmware lying around. I was wondering if anyone had any suggestions so i could burn DVDs. I also tried ripping with DVD Decrypter but it doesnt compress the ISO so then it wont fit on a DVD.
Results 1 to 16 of 16
Get a virtual drive like Daemon tools or Alcohol 120%
Mount the ISO in the virtual drive then then open in shrinksnappy phrase
I don't know what you're talking about. -
steve2713:tried reinstalling
sifaga: Programming exception
doppletwo: mount what ISO? i cant make one with dvd shrink. ive used daemon tools like once so maybe i just need a little more detail than what you're saying -
You can't use Shrink straight from the disc? Have you ripped the disc to the hard drive first then, using Shrink or DVD Decrypter?
steve2713: great idea so i just tried that but it started like normal and then the program just shutdown with no error given or anything
how can i check the registry to make sure? and how would i remove things? i havent messed with that at all in my time as a geek
and all i see is the up-to-date version of shrink -
forget the registry then, just get an old version of shrink from where fritz said
ok that works but the functionality is terrible. i cant make it to an .iso and burn with dvd decrypter, nor can it open an iso. its better than nothing so i definitely appreciate the help but is there anything you can suggest doing to get 3.2 working? what with the registry?
Get Daemon Tools to mount ISOs and IMG Tools Classic to create them. Once mounted, navigate to the virtual drive and open with whatever. Classic can make an Iso from a folder within which are your VIDEO_TS and AUDIO_TS folders. I use them all the time, you shouldn't be without them. Good luck.
P.S. Rejig is a good transcoder too.
Pull! Bang! Darn! -
get a better dvd burner for starters. i own a liteon 411 drive that i converted to a 811. i use it just to do some kprobe scans. or get a dvdrom to do the ripping for you. it would be helpful if you filled out the computer specs. then others could help you out. more info from you is needed.
Oh, another way eould be to rip in DVD Decrypter "File mode", instead of ISO mode.Originally Posted by ufhockey
Then open files in shrink instead of open disk.snappy phrase
doppletwo, I already suggested that and he already said it crashed doing it that way as well.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
dvd shrink- how much compression...
By Bletch in forum Newbie / General discussionsReplies: 15Last Post: 20th Jan 2012, 18:24 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 13:42 -
compression and DVD Shrink
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2007, 02:15 -
DVD Compression/Shrink Software Recommendation?
By Noy2014 in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 07:12
